jaycocamprs
May 12, 2018Explorer
We have the R250's in the LT235/85R16. They have most definitely been run below 45 degrees, even a few times approaching 20 degrees. I never knew to worry about it, and haven’t seen any ill effect. We have about 9000# on 2 6000# axles with about 2800# on the pin, just under 12000# total. So the load is on average just under 75% of max.
The prior set of tires were BFG Commercial TA's. They were bought in August of 09 when I upgraded our last trailer from 15” ST tires to 16” LT tires. 2 Years later we bought the Mountaineer and I had the tires switched. In early 2013 I saw a bulge in 1 tire and replaced all 4 with the Bridgestone R250's.
Did you remount the tires on the same side of the trailer, so the direction of rotation was the same?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
