FIRE UP wrote:
Just wondering, without starting a major debate, why do you keep buying vehicles that need modification in order to be towed when, you can buy several makes and models that are authorized by many manufacturers to be FLAT towed? Yeah, Toyotas for quite some time, have had a pretty good rep for dependability. But, again, there's other Manufacturers with reputable-dependable flat towable cars. Honda CRV comes to mind. That is unless it's a '15 and newer.
Jeep wrangler, anything primarily around '90 and later that's the 4WD models. Anyway, just wondering why you'd do that when it makes it harder to set up and, there's more to go wrong while you're towing.
Scott
I like the reliability of Toyotas and I am looking at the Yaris which saves me a lot of weight over the ones you mentioned.
