Dutch_12078 wrote:
FIRE UP wrote:
Just wondering, without starting a major debate, why do you keep buying vehicles that need modification in order to be towed when, you can buy several makes and models that are authorized by many manufacturers to be FLAT towed? Yeah, Toyotas for quite some time, have had a pretty good rep for dependability. But, again, there's other Manufacturers with reputable-dependable flat towable cars. Honda CRV comes to mind. That is unless it's a '15 and newer.
Jeep wrangler, anything primarily around '90 and later that's the 4WD models. Anyway, just wondering why you'd do that when it makes it harder to set up and, there's more to go wrong while you're towing.
Scott
I can't speak for anyone else of course, but when we were ready to start towing, we already had our very reliable 2002 RAV4 and really liked it as a daily driver. Given that, it was cheaper to just add the Remco pump than it was to trade it in on something else. When we wanted to update to a newer car, we found that our existing pump and tow setup could be swapped right over to a new 2011 RAV4 Sport that we liked except for the base plate. So that's what we did. Since I did all the labor, our only direct towing expense for the swap was the new base plate and probably a dozen or so wire ties. I should also mention that our 2002 RAV4 has had less than $300 in actual repairs since new, and we still use it as a second car when we're at our Adirondack vacation cottage. Our daughters also borrow it at times when their vehicles need to go in for service.
I like the Rav4, but would guess that it close to the CR-V in weight. It is interesting to note that Remco does not recommend a Lube pump for the newer Rav4s.
