pasusan
Aug 11, 2019Explorer
time2roll wrote:This is what I did. Our B has such a small water system that if I didn't let out some water at the kitchen faucet while water heating the relief valve would leak a bit. My manual (and the notice inside the door of the water heater) says that's normal. I just installed an expansion tank and so far so good.
For a permanent solution consider a small expansion tank.
Amazon - Shurflow
Expansion is an issue for closed systems. Mine would leak at the water pump fittings if the WH would heat a tank of cold water with no usage. Took a lot of time to eventually find the intermittent issue.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
