enblethen
Jul 22, 2016Nomad
Depending on the rig, you could locate a 12 volt constant source on the rear of the rig. My genset is in the rear, so I tapped it for a source for satellite. Same could be used for charging toad battery.
Could use compartment light that is switched in compartment.
Use a separate two wire connector for charge circuit.
Make sure you install fusing for circuit.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
