tatest
Aug 22, 2013Explorer II
rv-dreaming wrote:
I'm looking at a 2005 Chevy Colorado with a manual Trans. Owners manual is not real clear on RV towing.
Answer to original question is NO. Only specific manual transmissions.
Now you are getting down to specifics.
The manual transmissiom GM uses in the Colorado, GM does consider safe to flat tow. If a Colorado is flat towable, it will be because of the choice of transfer case in a 4x4, not because of the transmission. It has been a long time since GM has used any rear drive manual gearbox they want to let you tow, back to early '90s maybe.
Is the manual transmission offered in 4x4, or are those automatic only?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
