syndrome85's avatar
syndrome85
max tire psi vs door panel max load psi
Hello all,
I was wondering if anyone can help me with a tire pressure question. I have a 2006 dodge mega cab 1500, 5.9 hemi. I have a 26 foot starcraft ar-one wide body weighing about 5000 lbs. My tires say max tire pressure is 44 psi. My door panel says max load pressure is 70 psi. Normally I know to never exceed max tire pressure on a tire. Is there something different about towing that allows you to go above a tires max psi? When I put 44psi in all my tires they still look a little low. And when I put the trailer on the hitch it looks really low. Is it bad to put over the max tires psi when towing? Any anwers are appreciated. Thanks.
  • cjoseph wrote:
    Look up that tire and find out what the maximum WEIGHT rating is for it.
    Weigh your rear axle with the trailer hooked up and loaded up. Divide that by two. That's how much weight you are carrying on each tire.
    There may be a 2-digit alphabetic code at the end of the tire's sidewall description.
    Example: P275/75R-15 SL
    SL = Standard Load
    XL = Extra Load
    LL = Light Load
    No letters means standard load.
    With a max air pressure of 44, I'm guessing Extra Load. I would still weigh it.
    Don't exceed that tire weight rating and as already said, don't exceed the max tire pressure.
    If your tires are squatting at the max pressure, you are probably over weight on them. Just guessing.
    My standard loads were 44psi. My XLs are 50psi.
  • It appears the tires you describe are underrated for your truck. It is possible you are out of spec enough that you shouldn't haul or tow much of anything.
    One thing is absolute under any circumstances- NEVER, NEVER, NEVER overinflate tires beyond the max psi printed on the tires.
    Personally, I'd begin shopping for properly rated tires.
  • Look up that tire and find out what the maximum WEIGHT rating is for it.
    SL = Standard Load
    XL = Extra Load
    LL = Light Load
  • W.E.BGood wrote:
    "WARNING!!!
    You need to replace those tires IMMEDIATELY. You've got the wrong kind of tires and they are going to fail due to overloading.
    DON"T WAIT!! DO IT NOW!!"
    A bit of Chicken-Little here IMO. I just finished a 4700 mile 3-week cruise from eastern Iowa to northern California with both interstates and VERY twisty mountain roads and 8% grades. My '08 Tundra with "dangerous" P-rated tires @ 40 lbs. handled it all confidently and comfortably towing my 7,000 loaded Outback 25 footer.
    syndrome85...as others have noted, the original tire size/design/rating is different than what you have on it now. Use the existing pressure on the tire.
    Your Tundra might have shipped with P rated tires?
    The 1500 Megacab is a 3/4 ton truck. It has 3/4 ton axles, suspension, brakes and frame. Granted, the rear axle is the slightly lighter duty 3/4 ton version. No way this truck should be running light duty tires or wheels. If money is an issue look for factory take offs.
  • "WARNING!!!
  • CapriRacer wrote:
    syndrome85 wrote:
    Hello all,
    WARNING!!!
    Go to a tire dealer and have them look at the situation.
    NEW TIRES are required!
  • syndrome85 wrote:
    Hello all,
    WARNING!!!
  • Being the truck is a 2006 the tires were most likely replaced at least once. Sounds like the truck had LT tires when new and they were replaced with P series tires. Look at that door sticker closely and then compare it to the tires. The LT tires ride a little harder but are worth it when towing or you are loaded.
  • X2 on the wrong tires. Those tires are P rated. Looks like your door panel is saying that you're suppose to have LT (Light Truck) tires.
  • Are you using car tires? (P rated). You should be using LT rated tires. I would NOT exceed tire manufactures rating.
    Only advantage of using "P" rated tires is smoother ride - made or grocery-getters.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 05, 2026
