JJBIRISH
Aug 11, 2013Explorer
I already had my Max Air covers and the reason given to me for not recommending the use of the Max Air by FF themselves has always been because of the lid opening…
The one thing the video proves is that opening the lid farther wasn’t what was needed as it was opened only 3 inches for the demonstration to accommodate the different covers and still allowing for full airflow using their cover… that leaving the difference to be something else not the lid position…
So what are the differences causing the air flow differences… what I found with the old Max Air I have is they came with standard screening over the louvered portion of the cover… the screen not the lid and not the louvers being the most limiting factor… the cover used in the demonstration doesn’t come with the screening and obviously with all of the demonstrations and comparisons not once did they add their optional screening to see what that does to air flow…
As I said in my earlier post remove the standard screening if you have Max Air or any other brand with screening and the flow will be at least close to using their cover…
I hate marketing… or as it would be more appropriately called professional lying… but it works, most people buy into it so easily…
Put a marketer and a product liability lawyer together in one room and the results can be lethal…
I am not knocking their product but these demonstrations are almost always designed for the product … in other words the deck is usually stacked by only including that which you know will wow the viewer… now maybe their cover has a few more sq. in of louvers to, but wouldn’t make a lot of difference…
If you want to know do a little simple test of your own… stand in front of a box fan blowing on your face then place a screen between it and yourself and see how limiting screen can be…
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
