- lanerdExplorer III have three FF vents and I purchased 3 FF covers. Unfortunately, my front vent is located very close to my 360 OTA antenna and the FF cover would not fit. Returned that for a refund.
Recently, at the FMCA rally, I purchased a Maxair standard vent because it actually slanted back a little so I knew it would clear the 360 OTA antenna.
Once back at the park, I went to install the cover and found that my FF vents flanges were made such that the Maxair mounting brackets would not mount as described in the instructions. I had to go inside and remove the interior valance and lower the fan down hanging by its wires. At that point, I could put the retaining lock washer and nut (for the mounting screw) on the inside of the vent's flange. Reinstalled the fan and valance on the inside and mounted the cover on the outside and then everything worked fine.
So, you need to make sure that the mounting brackets supplied by Maxair will indeed work on your FF's exterior flange.
Hope this helps
Ron - Tango__AE7UIExplorerWe are also "one of the others."
I have the Maxair covers on both Fantastic Fans in both the bedroom and kitchen of our fifth with no issues and great results. - SCVJeffExplorer
IAMICHABOD wrote:
I'm one of the others
Yes, works just fine. I have done this for years as many others have. - Robin1953Explorer
burnmark wrote:
Yes you can use one of the "normal" Maxxair covers with a Fantastic fan. The only caveat is that the cover will not open fully with the regular Maxxair. I just watch to make sure that the front lip of the cover goes up enough to expose the full front vent of the Maxxair cover. With the one specifically designed for the Fantastic fan you can fully deploy the fan cover. The new Maxxair II will also work with the Fantastic fan.
Can you combine a fantastic fan with a "normal" Maxxair type cover? Will that cover block too much air movement? I already have the cover and don't want to remove it for one of the powered ones.
m
I had the cover specifically designed for the Fantastic fan on a previous TT. On this new OR one of the "normal" Maxxair covers was factory installed with the Fantastic fan in the bathroom. I had a second fan added to the kitchen at the factory and the dealer installed a Maxxair II over the kitchen fan. I use the one in the bath the most and it seems to operate just fine. The Maxxair II gives you more front vent area. - Mark_HeislerExplorer IIx2 Yes, works just fine. I have done this for years as many others have.
All my vents just have reg maxxis vent covers on them - Golden_HVACExplorerI also put Maxx air covers on my Fantastic fans back in 1997. Still all working, and the fantastic fan covers are not damaged by the sun, can leave them open in the rain, or while on the freeway!
Fred. - IAMICHABODExplorer IIIYes, works just fine. I have done this for years as many others have.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
