thomaskemper's avatar
thomaskemper
Metal camper step shocked my dog!
I realize that I have an electrical issue, as sometimes I get a little shock when I step into the cabin wearing no shoes. My dog got shocked on the wet step last night, and it really traumatized her.
I know electrical issues are a whole can-of-worms, but I wonder if anyone might have some tips and directions about me feeling my way through a repair. The last thing I want (of course) is my home burning down. If there is a short, how do I go about finding it?! I've had to dig into a wire harness before on my motorcycle, and so I know it's tough, but how are RVs wired?
I have a 1988 Toyota Dolphin. Two breakers that run 1) the AC, and 2) the outlets. I also have one solar-panel with four storage batteries that run the lights and water-pump.
So how would electricity be getting into the body of the truck? (For those of you who are concerned about my dog's well-being, know that I have installed a rubber mat on the step, so once I can get her over her PTSD and into the cabin through that door, she is not going to get shocked.)
I appreciate this forum and I hope that someone can help me solve this serious issue before I take off for a 2200 mile journey in three weeks (September 1st).
Thanks for any and all help.
~Thomas
  • RoyB's avatar
    RoyB
    Explorer II
    Small animals and little kids are more prone to getting a serious shock... I would unplug it until you get it fixed if it was me...
    I would plug in an extension cord for bare necessities and run off of that in your truck camper setup until you find the problem... I suspect something isn't wired right...
    Hope you dog is ok... This is nothing to mess around with...
    Roy Ken
  • Sounds like reverse polarity and a broken ground(either your cord, or the outlet). As far as I know, the ground and neutral should be bonded at some point so if you encounter an outlet wired improperly, instead of charging your vehicle body to voltage, that voltage will just short to ground and pop the breaker eliminating the charged vehicle body. If you have a broken ground, that can't happen and you are left with a shocking RV chassis.
  • Sounds like a "hot skin" condition.
    https://www.youtube.com/watch?v=Y8h64X33aKg#t=27
    Sorry don't know how to make it a link
  • You're not grounded. As stated above, possible broken wire, or the plug in your wire that runs to shore power is bad. But what you describe is a result you are not grounded.
  • Sounds like reverse polarity, probably at the power source you are plugged into.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
