Velvac is still in business and you can order from them or Amazon, etc. I had to replace the driver's side mirror. I ordered the entire assembly for $184 and had an RV repairman put it on. Mine did not have power, which made it a tad easier. My mirror had a part number on a label underneath the mirror itself. I was surprise it was still there and visible, being the coach is a 2004. You may be able to talk with Velvac about a replacement that would not be as heavy, but I replace with the exact same item.
Dale
