Dave H M wrote:
:S I think that i understand that OP now has power at the pedistal but plugged the RV in and it did not have power inside.
OR when he plugged the RV in did it break the continuity and kill the power at the receptacle?
If the power holds at the pedistal (that is good) then should we not charge on and look for the problem from the pedistal to inside the RV?
I have removed the rv receptacle from the pedestal and had to power on the wires. I went to the contractor and tightened the lugs and wire connections. I then checked the wires and had power there at the pedestal. I installed a new receptacle and checked the power before plugging in my rv and no longer had any power. So some where between the contractor and the pedestal I must have a break in the underground wire....
