I'm SO confused. Is power at the outlet but not into the camper? Sounds like 120 volt at the wires at the outlet but not out of the outlet. Correct? NO? Maybe a bad outlet? Some people are making the assumption that the wiring is in conduit and new wires can be installed. Is this right or wrong? Is there any chance that the camper outlet is downstream from any other outlet and maybe a lose wire at that point or is is for certain that this is the one and only outlet. Are there any splices anywhere? Is the wiring the same from when it leaves the main box to where it gets to the camper "like # 10 light gray type UF and ends up #12 dark gray uf or maybe white RX? " indicating a splice.
