Bob_Vaughn's avatar
Bob_Vaughn
Missing 120 volts
We came home from our 2 week vacation and plugged our rv into the rv plug in our rv port. A few days later my wife told me that we did not have 120 volts. So I unplugged the cord and got my volt meter out and sure enough no volts.....so I went to where it is connected to the master switch and 120 volts there so some where under the concrete the power disappears. Something is amuck.....
  • Did you pull you outlet and check the wires to be sure they are not burned or damage. Did you also check line to ground to see if the neutral was bad.
