bwessale's avatar
bwessale
Mixed Tire PSIs
I have a double-axle trailer and replaced the rear axle tires. I now have Carlisle RH on the front axle and Carlisle HD on the rear axle. The RH has a recommended pressure of 65 PSI and the HD has a recommended pressure of 90 PSI.
Should I run the two sets of tires at their recommended pressure, or should I run the rear tires at 65 PSI to match the front tires?
My concern is that if the back tires have 90 PSI and the front tires have 65 PSI, won't the back tires end up carrying 30%-50% more load than the front tires?
And if they do, does that matter?
I called Carlisle tire, and they recommended running each set of tires at their recommended PSI until I make the permanent fix and replace the front axles RHs with HDs.
Thanks,
Bill
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
