carringb
Jun 17, 2013Explorer
mkirsch wrote:
Gas tuners only impact performance at WOT.
Do you drive around with the gas pedal mashed to the floor all the time?
If your answer is no, then a tuner/chip/programmer is a waste of $$$. The only performance it improves is of the stock price of the company that produces it.
Same goes for the "cold air intake."
Not true on my V10. The Predator advances timing and also increases spark, so it provides gains throughout the throttle range. It increases spark enough (by adjusting dwell time in the coils) that it cut back spark plug life by about 40%, so I switched to Irridium the last time around to get back on a 100k tune-up interval. No only that, I allows my free reign over shift points and rev limiters. The V10 stock is tuned VERY conservatively. FWIW I still run 87 octane.
My AFE stage-2 intake made a noticeable improvement in part-throttle power, to the point where I can pull steeper hills in OD, and solo can pull steep hills at 1200 RPM. I actually had to increase fuel delivery further at WOT using the Predator, because the AFE was flowing enough to exceed stock parameters, and it was leaning out beyond ~95% throttle.
That said, I suspect either the AFE intake or the programmer would not provide the same gains if I didn't already have the Banks PowerPack. You really have to open up both ends, and then use the tuner to take advantage of the better breathing. Doing it right isn't cheap, and with aftermarket support available for the 4.6L, that's why I think a supercharger may be the way to go. I don't think breathing and tuning will have near the affect on the 4.6L compared to the V10.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
