bowler1's avatar
bowler1
More Questions on Backing Up with Trailer???
A couple of quick questions on backing up. I know there is a lot out there on backing up but my questions might be a little different. I am fairly proficient at backing up and maneuvering my trailer, but two things still get me. I have a 29 foot travel trailer for what it's worth....
1. Backing up in a straight line. I always have trouble doing this. It would seem that this would be easy but I always drift to one side or the other...often without realizing it. When backing up straight I try to pull far enough forward to get the trailer in line with the tow vehicle. But then I have pulled so far forward that I have a long way to back up which is when I start to drift even when keeping the wheels straight.
I look out the back window over my shoulder and try to ensure that the truck is in line with the trailer, but this doesn't seem to work well enough. I guess maybe I should use the side mirrors when doing this? Or would looking straight forward and ensuring the tow vehicle is going back in a straight line a good technique?
Any advice or tips?
2. When to initiate a turn. The other problem I have is that I still have not figured out how far forward to pull the trailer in relation to a camp site before starting to back up. I can maneuver the trailer well, but seems that I always start the turn too far forward or back. This results in the trailer being off center in the site. I am still trying trial and error but have not gotten it right consistently.
I also find that that whether the turn is 45 degrees or 90 degrees seems to make a difference as well.
When backing into a site (for consistency mostly) I start backing up with the steering wheel jacked all the way in the direction I want to turn and then start to "chase the trailer" once the angle is about right. Maybe jacking it all the way is not always best...???
thanks for your help
Matt
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
