schlep1967
Jul 06, 2016Nomad
bowler1 wrote:
A couple of quick questions on backing up. I know there is a lot out there on backing up but my questions might be a little different. I am fairly proficient at backing up and maneuvering my trailer, but two things still get me. I have a 29 foot travel trailer for what it's worth....
1. Backing up in a straight line. I always have trouble doing this. It would seem that this would be easy but I always drift to one side or the other...often without realizing it. When backing up straight I try to pull far enough forward to get the trailer in line with the tow vehicle. But then I have pulled so far forward that I have a long way to back up which is when I start to drift even when keeping the wheels straight.
Keep a slight angle with the truck to the left of the trailer so you are basically backing in a slight arc. It is easier than going straight back.
I look out the back window over my shoulder and try to ensure that the truck is in line with the trailer, but this doesn't seem to work well enough. I guess maybe I should use the side mirrors when doing this? Or would looking straight forward and ensuring the tow vehicle is going back in a straight line a good technique?
Learn to use the side mirrors at all times. Practice is key. I would practice more in situations where backing straight is not possible. Very few campgrounds have room for you to pull forward enough to get straight.
Any advice or tips?
2. When to initiate a turn. The other problem I have is that I still have not figured out how far forward to pull the trailer in relation to a camp site before starting to back up. I can maneuver the trailer well, but seems that I always start the turn too far forward or back. This results in the trailer being off center in the site. I am still trying trial and error but have not gotten it right consistently. You can never be to far forward or past the site. As long as you are past the site you can adjust when backing up. If you are not past the site it is very hard to get turned enough to get the camper back into the site and then get the truck back in front of it to make it straight.
I also find that that whether the turn is 45 degrees or 90 degrees seems to make a difference as well.
When backing into a site (for consistency mostly) I start backing up with the steering wheel jacked all the way in the direction I want to turn and then start to "chase the trailer" once the angle is about right. Maybe jacking it all the way is not always best...???
Jacking it all the way is not the best way. Do a google search for the scoop method of backing a trailer.
thanks for your help
Matt
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
