Mike_in_DE's avatar
Mike_in_DE
MPH vs MPG
I bought a 2022 Chevy 3500 6.6L Duramax Turbo Diesel and wanted to check the fuel economy for both towing and not towing. The numbers you'll see DO NOT include regen periods where the engine is burning excess diesel to convert soot in the DPF to ash. Also, the figures are from the truck's DIC (Digital Information Center) screen where the truck calculates the MPG via the trip gauge. Some people say those numbers aren't realistic and tend to be higher than actual. However, I checked those figures with eight stops at the pump (1400 miles in total), manually calculated the MPG and found there was good agreement between the two (within 1% on average). These were NOT fill-ups, rather, they were partials and averaged 14.5 gallons per refill.
You'll see in the table the term "equation". This is the MPG using the trendline fit on the plots I generated. It's an arbitrary curve fit but does match the data pretty well. I'm simply comparing the curve fit with the averages for the speed increments I ran.
I am pulling a 2018 Highland Ridge 5th wheel that is 32 feet long and weighs about 9000lbs loaded.
Hope this is useful to some folks!
https://ibb.co/BCWxTkp
Looking for advice before your next adventure? Look no further.25,129 PostsLatest Activity: Apr 26, 2025
