Sled208
Apr 02, 2016Explorer
Bessie-Hunter wrote:
Check that the pads of the Companion and make sure they set firm on the bed at the rear of the hitch. Others with the newer GM's (2011 to current) have a slight arch in the bed with the apex at the wheel wells, including mine. This results in the hitch flexing for and aft causing the pads to dent and cut the bed where the pads stop. This may be causing your problem, just a thought.
Very good point and I should mention that was the first thing I did. I had to take a bunch of material off of the pads to get it flush. I'm very surprised that the box of the truck is even needed to steady the system. Can't believe the hitch base can't handle it alone.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 19, 2026
