rhagfo
Apr 10, 2016Explorer III
donn0128 wrote:
MORE TRUCK!
Sorry to be the bearer of bad news, but Cedar Creeks can be very pin heavy. Loaded ready to camp, and drive across a set of scales. You will quickly understand where your peoblem is!
The issue is likely with the TV, but NOT the weight it is carrying! Unless the OP's springs are so soft the he is extremely a$$ low as to greatly change the drive shaft angle, not going to be the issue.
I would agree with broken Motor or transmission mount, bad U joint, or center carrier (if so equipped).
Heck, our 5er has about the same dry weight, and a higher GVWR (by 20#'s), and we CARRY and tow it just fine with our 2001 Ram 2500, with stock springs, and no bags!
"You Need a BIGGER TV is not always the answer"!!!!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
