EydieG's avatar
EydieG
Need advice on towing a truck
I realize several similar threads have been posted but none were exactly what I needed. We have a 38' diesel class A. Right now we are towing a Ford Taurus on a tow dolly. That is no problem but we would rather tow a truck. My husband likes to go fishing (everywhere we go) and he would rather put his fishing gear in the back of a truck instead of the trunk of the Taurus if he has to drive to a fishing spot. We plan on a used truck and manual trans. would be fine also. Any advice on what models we should take a look at? We would be okay with towing either with our dolly or 4 down.
Thanks!
  • Hi,
    There are several 4 wheel drive trucks that you can tow 4 wheels down, many of them with automatic transmission if you like it that way.
    Check here for the correct brackets. RoadmasterInc.com
    Fred.
  • Ill stay out of the tow capacity discussion but one thing you may have to deal with if you tow four down is a drive shaft disconnect. If it is a 4X4 this is fairly easy if you have a manual transfer case. If not you will either have to manually disconnect the driveshaft every time (what we do) or put on a driveshaft disconnect kit. It takes Angela about 5 minutes with a cordless ratchet to disconnect the driveshaft at one end and place in a hanger we made. Same thing in reverse. This is on an E350 based small motorhome we sometimes pull behind the pusher. Clearance is easy for her to slide under. Depending on the truck it should be the same.
    Just something to think about.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
