09KZMXT266
Apr 29, 2013Explorer
Chuck&Gail wrote:
What WD hitch? Very few have built in sway control like Equalizer or Reese Dual Cam have. Dealers often install very cheap useless******unless you don't let them.
Also you need to verify total weight and tongue weight. You need 13% to 15% of total TT weight on tongue. If you just add weight in the rear, sway will get worse fast.
Where is fresh water tank? On last two toyhaulers we adjusted tongue weight with the amount of fresh water we carried.
I believe it's this hitch:
https://www.etrailer.com/Weight-Distribution/Pro-Series/49569.html
with no sway control installed yet. I do have a friction bar I can add if that will help, but I'd like to eliminate the sway before adding the anti sway.
I haven't weighed anything yet, so I can only go off of what I've heard. The truck is just over 4k#'s and the trailer is 3600#'s dry with a supposed 620 TW.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Mar 13, 2017
