Roam_Schooling's avatar
Oct 05, 2015
Sway bars advice
Ok, so our rig is a 2003 Excursion towing a Jayco 287 TT (about 30 feet long and 6200 lbs dry). Took her for her maiden voyage from Kansas City to St. Louis for a few days. The Excursion pulled the TT great! BUT...there is a bit of sway. I've got a Fastway e2 WD hitch with sway bars connecting the TV with our TT. But when semi trucks come up alongside us, or when the wind hits the camper, there is a bit of sway. I understand by physics alone there will always be some sway. I get that. But my question is, if I add a Hellwig sway bar underneath, will that cut down on that sway? Significantly or just a little bit? Or, is there another suggestion you may have about helping with the sway. Mind you, I can live with it if need be. But it does get a bit tiring to constantly readjust that wheel from sway. Thoughts?
Looking for advice before your next adventure? Look no further.25,201 PostsLatest Activity: May 29, 2023
