JConatser
May 01, 2013Explorer
09KZMXT266 wrote:
... I guess that means I had 800 lbs of tongue weight which was 150 lbs. more than the max Toyota says which is 650 lbs. ...
Hitch receivers have a "with" and a "without" WD rating... is the 650 with or without WD?
Note also that your TT's tongue weight "is what it is" regardless of how you adjust your WD hitch. A WD hitch does not change a TT's tongue weight; what it does is distribute that weight between your TV's front and rear axles, plus your TT's axles. So, if your TT has a tongue weight of 800 lbs, and if your TV's hitch receiver is rated for 650 lbs (with WD), then you are over it's limit by 150 lbs---regardless of how you adjust your WD hitch. While the angle a trailer is setting relative to the ground will change it's tongue weight slightly, the significant way you change it is by how you load it.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Mar 13, 2017
