09KZMXT266
May 03, 2013Explorer
lrak wrote:JConatser wrote:
Mainly note, however, that your current Total weight of 8700+ is already greater than the maximum Toyota calls for (8100); once you add your 1000 lb. motorcycle, plus probably another 300 - 800 lbs of "stuff", you're gonna be 2000 lbs or so over their maximum limit.
Bottom line, (assuming the Toyota numbers I found are correct) you need a bigger truck.
FWIW, GCWR with tow package is 11,100. 8,700 is less than 11,100.
Correct, about the GCWR of 11,100, but he was correct about too much weight on the front axle. Actually, I was going to go from dropping 3 links to two on the WD Hitch. This should correct the FGAW especially if I put the Harley in the back.
I have basically decided to buy a new truck. Probably a 1/2 ton F150 would be enough for this toy hauler. But, before I do get the new truck, I'll throw some stuff in the back of the trailer to see how weight in the back affects things. If it helps, I may reconsider, but I'm pretty sure I'll be upgrading.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Mar 13, 2017
