BarneyS
May 10, 2013Nomad
09KZMXT266 wrote:carringb wrote:09KZMXT266 wrote:
Okay, now you're scaring the heck out of me. :) Guess I still have a lot to learn. I would have thought that if the truck by itself weighed 5000 lbs without a trailer and 5500 lbs with one, the TW would be 500 lbs. 5500-5000=500?
True, if you have the trailer sitting on a regular ole hitch ball. Not the case with weight distribution, since the trailer axles have to react the same moment which picks up the back of the truck and put weight on the front axle.
So, assuming it was a WD Hitch, would the TW be more or less than 500 lbs.?
It would be less. It would be around 400lbs if you weighed it with the WD hitched up. The extra 100lbs would be found on the trailer axles because the chains on the WD hitch are pulling down on the trailer A frame at the same time they are pulling up on the bars.
Barney
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
