09KZMXT266
May 12, 2013Explorer
09KZMXT266 wrote:BarneyS wrote:
When using the tongue weight scale, be careful that you get the weight pressing STRAIGHT DOWN on the scale. It is very easy, when you put the device under the coupler, to have it just a very small bit off center of the coupler which will cause sticktion in scale and throw off the reading quite a bit. Good idea to take several readings in succession to make sure it is consistant.
Barney
Any advice on how to do that? The coupler is like 18" to 20" off the ground. I guess I need to fabricate some sort of stand for the scale that is like 13" or 14" tall. If not, I'll just put the scale on the ground and lower the jack onto it.
Never mind, I searched this forum and found lots of info on how to use the scale. :)
Looking for advice before your next adventure? Look no further.25,201 PostsLatest Activity: May 29, 2023
