Chippendale's avatar
Chippendale
Need an opinion on tire swap
I am in the process of purchasing a new Heartland Gateway 5th wheel, and of course it has Chinese tires on it. We were in Santa Fe in August of 2012 and had to purchase a new set of tires to get home. All Discount Tire had were LT 235/85 R16 Load Range E Michelin tires, so I bit the bullet and purchased them. The manufacture code says they were made in May of 2012.
I am just wondering if the 2 year old Michelins would have more life in them than the equipment Chinese tires will have. I am wondering if I should go to the hassle of getting the dealer to change them out. I am not trading the old rig in, I am taking it to PPL for them to sell it for me. I am sure I will have to pay them to change the tires.
Anyone have any suggestions?
Thanks
  • Ivylog wrote:
    Going to be hard to find a 16" tire with a higher load rating than his 235/85 R16 Load Range E Michelin tires.
    An LT265/75R16E has a higher load capacity and the same diameter. Note that ALL tires of the same size and load range have the same weight capacity!
  • Jhuff8181 wrote:
    donn0128 wrote:
    They are still only rated at 3042 each. G614's are rated up to 34 something. But they require wheels that can handle 110PSI to achieve that rating.
    If a person needs more than 3042 each they would be wise to upgrade to 17.5 inch wheels and tires with upwords of 4000 pounds load rating each.
    My fifth wheel has a GVWR of 15,500 lbs. The G614's have a dual load rating at 3415 lbs at 110 psi. They cost about $320 each. For five of them that's about $1800 mounted and balanced. Going up to 17.5 will cost about $3500 for tire and wheels. Is it worth the added costs?
    What were the OE tires on that beast?
    I would try to use 225/70R19.5 truck tires before swapping to oddball 17.5's.
    Thanks
    A lot is going to depend on the model Gateway you're purchasing. Some have 6000# axles and others have 7000# axles derated to 6750#.
    FastEagle
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
