BarneyS
Jun 15, 2015Nomad
coolmom42 wrote:BarneyS wrote:
I suspect a ground fault interrupter has tripped somewhere in the trailer. Look in the bathroom first. Same thing happened to me and after about an hour of trying various solutions I found the tripped breaker. Probably your fix is going to be as simple
as pushing a button. I hope so. :)
Barney
GFCI is on the 110 outlets, not on the 12 V lighting system. OP states microwave comes on, so at least 1 of the 110 outlets has power.
Don't think GFCI is the problem here.
Sounds like a new battery is in order, and then possibly an upgraded converter.
Yep, you are correct. Brain Fart here. Sorry.:o
Barney
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
