Artum_Snowbird
Dec 05, 2017Explorer
Never push on a check valve with anything unless there is no pressure behind it. Drain all pressure, push the check valve, then start the pump for a few seconds or open a tap slightly. Do not let pressure build up.
If you push on a check valve when it's under pressure, you will blow the valve and need to replace it. Simple to do, but not necessary.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
