jbluetooth
Aug 06, 2018Explorer
Grit dog wrote:
First, yes, move some weight rear-ward and try that. Can you not put the other bike from the truck bed into the TH? That would ease up on the truck rear axle weight significantly. Typically toy haulers are designed nose heavy to offset the "toy" weight in back.
What are you defining as sway? Some wiggling back n forth when changing lanes or correcting steering, OR uncontrollable sway that doesn't go away until you apply trailer brakes or slow back down to below a certain speed?
If you have E tires, airbags and some weight distribution, IMO the truck should handle it ok (aside from possibly being over hitch load ratings).
Thanks for the input. Its funny the things you realize when you write it down hehe. I've reloaded the trailer a bit and will drive back over to the scales to see if I'm better balanced with a lower hitch load. Maybe that's all I needed to do now that the hitch is setup better and I have the airbags. In this situation I have my standard load and the extra bike is something non-standard, which is why it ends up in the truck bed. usually I won't have it.
As for the sway, the truck tows fine in a straight line. But when I pass a semi, I get pulled into it bad enough that it's scary and I see the semi swerve a little out of the way in my rear mirror. Same thing if the wind blows, it just pushes me around more than I would like.
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 20, 2026
