enblethen
Aug 11, 2013Nomad
Your MHs ground needs to be connected to the ground adjacent to the battery in the Suzuki.
You need to put in some diodes to block the MHs power from going back into the Suzuki's system.
You converter may need the same ground. What is make and model of the converter?
I am guessing you have red turn signals on MH. The converter should be a two to three not a three to two.
I installed the converter on the back of MH. Then ran four conductor to the rear of the Suzuki into the void behind the tailights.
This is the way I did mine:Roadmaster diagram
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
