enblethen
Aug 12, 2013Nomad
Those diodes will work.
You may need to get "red" 1/4 inch female connectors. The wire in the Suzuki is smaller then the "blues" will properly crimp to.
Suggest putting electrical grease on the wires prior to crimping.
I also instelled the diodes in the tailight harness not in the main harness. When you pull the tailight, you will see a harness connector about 12 inches from tailight assembly.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
