Grit_dog
Nov 19, 2019Navigator III
www.bcae1.com is a good source to learn about DC electricity and circuits.
The other thing is any negative wires will (should) be continuous to ground, so with a multimeter you can check continuity to every wire and all that are continuous to ground (the chassis) are neg. All others are positive.
Otherwise can't help without seeing the setup. IE house loads vs chassis (starting and vehicle power like the wipers) loads.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 05, 2026
