navajochief's avatar
navajochief
Need Help With Determining Weight Numbers
Truck and Trailer together: 21,540 lbs
Truck only: With Hitch attached: 8,060 lbs (GVWR) 11,400 lbs
Trailer at rear axles: 10,240 lbs
Front GAWR: 5,700 lbs
Rear GAWR: 7,000 lbs
I wasn't able to get the vendor to weigh my axles individually and/or my hitch weight as well.
So this is what I got on my own:
Hitch wt: 3,240 lbs
Total wt of trailer: 13,480 lbs
Is my math right?
I weighed myself at a public truck scale in town that told me they weren't able to help me with weighing my hitch weight and axle weights individually. I plan to go to our local CAT scale the next time for comparison. However, with the numbers I was able to get this is what I got for my hitch weight and total trailer weight.
Thank you.
Mark
  • Looks right to me.
    Total combined weight: 21,540
    Trailer axles: 10,240
    Truck: 8,060
    Subtract unhitched truck, and trailer weight from the total weight leaves 3240 lbs. which is the weight that sits on the truck with the 5th wheel attached, i.e. hitch/pin weight.
    FWIW that works out to 24 percent hitch weight, might be a bit high but don't know if this is a toyhauler or a standard 5th wheel or what.
  • Fill in your signature.
    Bottom line what does your rear axle on the TV weigh hitched and fully loaded?
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
