ksg5000
Sep 23, 2017Explorer II
First thing I would do is switch to the water pump - even if you have even a slow leak the water pump will periodically turn on as pressure drops. If the water pump never turns on then your issue is likely related to water pressure or maybe rain etc. Doesn't help diagnose a fitting which won't handle higher pressure but will help eliminate possibilities.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
