DownTheAvenue
Sep 23, 2017Explorer
kabbro wrote:
BINGO!! There is now water seeping out of the enclosure just like the other night. The amount of information and knowledge on this site is astonishing. Thank you!
I haven't taken the time yet to get into the "rat's nest" and determine exactly what fitting is leaking,but will attempt to do so later.
One question, if I made a new routine where I was sure to turn on the hot water faucet just as the water gets hot so as to relieve the pressure that's built up, do you think that would prevent leaks (lazy man's solution if I have trouble finding the leak in the "rat's nest")?
The pressure relief valve is doing its job, releasing water as it heats up and expands. The air pocket at the top of the inside of the heater has been compromised. Darin and refill. Better yet, just install accumulator tank.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Mar 30, 2026
