Optimistic_Para
Jul 10, 2018Explorer
Engels is good. Couple of things to keep in mind:
Unlike the 110 volt household freezers, these dual voltage units - Dometic, Engel, Arb, and a few others - are designed for use on boats and expedition vehicles, and are far more rugged than a household item needs to be.
As someone else mentioned, they can also be used as refrigerators as well as freezers, thus they are more versatile and useful.
Finally, with most of them, if you've got them plugged in to both 120 and 12 volts, they will run on the 120 but AUTOMATICALLY fall back to the 12 volt and keep running if something interrupts the 120 volt power. This can save you hundreds of dollars in food that DIDN'T spoil if you were away when the power went out.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
