dspencer's avatar
dspencer
Need some real life advice
I'm due to replace the tires on my 2012 Silverado 1500 ext. cab and need some real time advice. I'm hearing a lot of decent things about select Firestone Tires. This is a daily driver and I need a tire that will also work well in snow in the winter. I need some real life advice on what your experience is with the Firestone-Bridgestone tires both LT and a P rated as I'm torn which way to go. FYI I'm pulling a TT loaded out between 6000 and 6500lbs.
  • I run load range E on my F250 and my fiver when I was pulling my fiver and the rear tires were maxed out I had Zero problems with them and still running them. I will take Firestone over Michelin for the price alone as the life expectancy is about the same. I have noticed that the Michelin's seam to have softer sidewalls and I certainly don't need that.
    To each his own.
  • I have several sets of Firestone Transforce LT tires. Both the AT and HT tread design. Had them on my trucks and also on my 5th wheel.
    I have found them to be really nice tires. The HT tread is a little quieter than the AT. But the AT (for All Terrain) is not all the noisy. The Transforce is also very reasonably priced. I think the last set I bought the tire price was $180.00. Balanced mounting and all the taxes added the total was just under $1000. These were 4 tires Size LT245-75-16E. And mounted on my 5th wheel. Set before that were mounted on my Truck. Can't remember the exact size but they were LT E range 18" and priced at about $1100 Total.
    Have never been disappointed with any of my Transforce tires. I recommend them highly. Although I think LT E range tires might make your ride a little rougher on your 1500 half ton.
    I tend to steer clear of Michelin and Goodyear brands. Have not had great experiences with either of them. And...OH...the price you pay for them. UGH! I just don't think the value is there, like it used to be.
  • I've had 2 sets of Destination LEs ("P" rated) on a different truck. Excellent in snow. I wasn't towing as much weight as you are though. If I did those with that weight I would go with Destination ATs. P tires are OK for towing so long as you max out the PSI when towing.
  • While I appreciate your feedback on Michelin's, I have had the Michelin brand more than once and it was a very average tire in my experience. I specifically ask about Firestone's please.
  • Cummins12V98 wrote:
    I would go MS2's in a D or E rating.
    This is what I have on my Silverado and it did great in the snow this year.
    Bruce
  • Unless you want a very aggressive mud or snow tread, my choice would always be the Michelin LTX MS. Not dissing your tire choice but I have always had great service with the LTX MS tires. Granted, I probably get no snow compared to your location.
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 25, 2025
