BarneyS
Jul 13, 2018Nomad
If you do not get as much tension on the bars as you need just tilt the hitch head rearward some more before you begin. That probably would have solved Soundguys problem and allowed him to use the Straptek system.
By the way, in most cases the trunnion style bars are not supposed to be parallel with the trailers A frame. They are designed to point downwards a bit when properly tensioned.
The round bars should be parallel due to the way they are designed.
Barney
Barney
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
