SoundGuy
Jul 13, 2018Explorer
BarneyS wrote:
If you do not get as much tension on the bars as you need just tilt the hitch head rearward some more before you begin. That probably would have solved Soundguys problem and allowed him to use the Straptek system.
Wish that were so but it's not the case. I needed to drop the hitch ball 1.5", which meant disassembling the head and starting all over again. It's not a head angle issue, it's currently set exactly as it needs to be for proper weight transfer to the truck's front steer axle.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
