mkirsch
Jul 17, 2018Nomad II
If you are jacking so high, that means your spring bars are not heavy enough. You need the next higher rated spring bars.
The next higher rated spring bars will require less angle to achieve the same tension, and therefore less jacking to get them attached.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
