mkirsch
Jul 18, 2018Nomad II
Changing to heavier bars WILL change everything...
The heavier bars will not need to flex as much, so you can install them at a less severe angle to achieve the same weight distribution. Closer to horizontal. Less angle means less jacking.
...and you're going by the ADVERTISED hitch weight? You know they're never even close to right. If you weigh it you may well find that you're on the high side of the current weight range. What's the next step up? 1000-1400lb bars?
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
