stevepk's avatar
stevepk
Need WDH help
2014 F150
1996 24 foot Mallard TT
Bought the trailer last fall and the seller delivered it, so I've never towed it. Trying to get the WDH set up. Trailer and truck on level ground, trailer level. I have 2 1/2 inches from the top of the trailer hitch to th top of the ball. The Hitch is adjusted to its lowest position.
Do I need a different shank? I believe it's a Reese but can you still get a different shank for a '96 hitch?
  • Sounds like you do need a shank with more drop. They're pretty standard, even between brands. You could try local hitch shops, ebay, etrailer, maybe even craigslist.
  • Additionally Etrailer has a lot of good info and some videos.
    In short, yes it sounds like you need a shank with a longer drop.
  • No I understand that the measurement from the hitch to the top of the ball should be one inch for the initial setup. I'm I wrong?
  • A picture would help lots...
    Do you mean you can't lower the trailer tongue enough to get on the ball without being nose-down?
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
