Hartos's avatar
Hartos
New 4" heavy duty bumper cannot fit Rhino drain hose inside
We recently had a new 4" heavy duty bumper fabricated and welded to the frame by a local RV dealer. The thicker steel has caused our Rhino drain hose to not fit inside due to having slightly smaller inside dimensions than the standard bumper. I saw a few videos on YouTube where some recommended using a Dremel to slowly grind down the high spots on the Rhino fittings until it fits which seems like a sewage spill waiting to happen someday with thinner hose fittings. Is that the only way or are there hoses out there designed to fit a smaller inside bumper dimension?
I should also note, i am hoping to avoid a separate PVC pipe attached to the bumper, i see some RV's with that also which may be partially due to this same issue, not sure.
Thanks!
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
