emillsboro
Sep 15, 2015Explorer
I got rig weighed at CAT scales. Go online and google CAT scales to find closest place. Also online go to "Trailer Life" towing guide where they have step by step guide and you can fill in the weights and get a report of your rig's max and min condition. You'll have to weigh the combine rig and then just the truck separated from 5er. I did it on two separate trips to scales. Cost is about $10 each weigh in. Tell operator it is first time weigh in. Note, the button to talk to operator is way up high for semi drivers. You'll need a step ladder or a stick to reach the button. Position your front truck axle on the front scale, your truck rear axle at the second scale and the 5er on the last scale. Once operator tells you they have the weight pull off scale and go inside to pay and get weight report.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
