JIMNLIN
Sep 17, 2015Explorer III
After just spending close to $4500 in the last 3"weeks...my husband just took the truck for a ride down the highway with nothing In tow and around a corner and almost lost control....
Something was done wrong if the truck drove fine before the 4500 bucks was spent.
Now if new tires were added then they could be the problem. New tires need to be broke in for 2-3k miles.
Some AT tires with the larger lugs and voids and MT type tires can have lots of tread roll. This can let the back end come around on hard cornering and handle like the rear tires are half flat.
Using 80 psi in all the tires when empty can have handling issues just like the two points I mentioned.
Wrong width wheels for the tires width being used can also have bad handling issues same as above. .... Example is a 285/75-16 on a 6 1/2" wide OEM wheel. This leaves the tires tread rounded or balloon shaped and just rolling on the center of the tires tread causing bad handling issues.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 05, 2026
