Cummins12V98
Sep 20, 2015Explorer III
"e rated green tire that,is too soft" What the He!! is a "GREEN" tire?
Put 72psi in the front tires loaded or unloaded, run 45 rear unloaded and 80psi loaded.
As far as air bags 75psi is WAY too much. Have RV attached and air so that the truck sits "LEVEL".
Take your truck to a quality frame and axle shop to get it aligned and check for worn parts.
Are you SURE they installed "E" tires? Exactly what tire was installed?
Bottom line as far as your RV is concerned it's WAY too much for your truck. I will bet you are over your rear tires capacity.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 04, 2026
