rhagfo
Sep 23, 2015Explorer III
mkirsch wrote:TXiceman wrote:
Softer tire will not get a longer thread life. I think your RV is too much for the truck. The answer is smaller trailer or larger truck.
Did you miss the part where the OP is losing control of the truck unhitched?from page 3 wrote:
the trUCK is all over the road with out the trailer and all the air out of the bags...something is definitely wrong but noT sure what and we have had a couple of people LOOK AT IT...DH is beside him self with frustration so I will continue to do research and try to locate someone.who. Might specialize in front end problems...
It's a Dodge, notorious for the "Death Wobble."
Maybe, but is is not normal, I have never had the "Death Wobble" on my 2001, and it has 287,000 miles, drives where I point it Michelin M/S2+ tires 265/75-16 E's. Tire Pressure Front 65 to 70 psi, rear empyy 45 to 50 psi loaded 65 to 80 psi.
I also disagree with tires needing to be driven in for a couple 1,000 miles to get broken in.
I would be checking every joint in the front end, this would include the steering shaft, ball Joints, tie rod ends, Track Bars, control arm bushings.
Go to the best front end shop you can find.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
